Cooling fan on permanently
Tags
cooling fan
26K views 9 replies 4 participants last post by  Psycosis
#1 ·
This issue cropped up recently, just out of the blue.
The fan comes on full power as soon as the engine is started, it continues for a while after the engine is switched off.
I have checked the coolant and that all seems to be ok and nothing appears to be leaking.
I don't get any warning lights on the dash.
I read that this might be the CST, that the fan could be in some sort of safe mode.
I have recently moved to New Zealand and i reckon its going to be expensive to get this fixed if I have to get any parts from Australia.
Cheers guys
Discussion starter · #3 · (Edited)
Do you know how to do this with an aftermarket head unit fitted. I.e. with just the steering wheel controls
I pushed the two pedals down and i get the code 11508 then 00000. This may point to some sort of issue, can't find the fix or exactly what it is(did a google search and it seems possible its a sensor)
Any specific ideas?
Code 115 indicates something to do with cooling, no idea about 08 though.
Discussion starter · #6 ·
Stupid question then, where exactly is the sensor.
Is this sensor the one in the radiator or somewhere else?
Discussion starter · #7 ·
I have recently plugged the car into one of the ODB II dongles and I have an old stored error relating to the temperature sensor with a reading of -40, it states this freeze section could be old, not sure if this is relevant.
The car got upto 95c when driving and I didn't hear the fan coming on, which is slightly concerning. how hot should then car be getting when driving?
