The dreaded P2279 Fault Code
27K views 17 replies 6 participants last post by  astra_fan
I had same fault code appear last month, cleaned boost pressure sensor, cleaned Egr and around inlet what I could get at and checked that swirl flaps are working ok. After I had cleaned these I then cleared the fault code with a scanner and has been fine since. (Fingers crossed) I use redex but might try something else in the future if it rots the injectors!
