Vibration Under Load.
12K views 29 replies 9 participants last post by  paulbradbury1970
#1 ·
Hello,
need some advise. When I accelerate in 4th 5th and 6th hard I get a horrible vibration through the car does anyone else have this problem or ever experienced it or could possibly help resolve it I've just has a second clutch and flywheel this year it seems like the clutch doesn't disengage properly and the slave cylinder is rattling again and the clutch is very high as it was before i had it changed.
My clutch doesn't seem to disengage properly and makes a knock when I goes into some gears. I just have the standard pentas I get a wobble at 80 but I think that's the broken rear coil spring. It's getting really on my nerves. Kinda thinking of getting a loan replacing the gearbox and clutch again. :(
#7 ·
it does it when accelerating hard if i accel slowly i dont have a problem when im just slowing accelerating i thought i was a box problem... had the box checked.... apparently its fine.
i really dont have a clue i have had 2 different people do the clutch and flywheel so im stumped.
#13 ·
Just spoke to a suspension specialist about getting a full geometry done and mentioned the vibration under acceleration problem. He thought it was a known vx issue and described it to me. Its is what he described. He thinks it is a cv joint problem. probably one of the inner ines has lost the grease or dried out - he said to check and grease them and thatmight fix it but if its is knackered a new cv or driveshaft will be required.
Where is the best/cheapest place to get cv's/driveshafts ??? They seem to be expensive.
