Evening all
New to the site after just buying a 2014 Astra J 1.6 petrol 113bhp i believe ?
First thing i noticed was a lack of power so i got a diagnostic test done which came back as Mass Air sensor. Before getting a new one i have checked the filter and induct pipe to filter box to make sure all is how is should be. ( looks fine and not blocked )
Then i have just noticed that the engine cooling fan comes on as soon as i start the car ( even when engine cold ) is this standard on this car ?
With the cooling fan on high and the start of the air induct pipe just behind the radiator would the fan cause to much air or draw air away from the induct pipe.
Seen utube clips of how to test mass air sensor with multimeter ( anyone recommend )
How can i unplug the cable to the fan to see is it makes a difference, if not i will get a new mass air flow sensor hoping that will solve it.. no engine management light unless unpluged..
will say that the car had a bump on the front which needed a new radiator and replaced and all fixed before i bought the car.. hopefully they put the front end back together properly
thanks all
thanks all
