Astra 1.7DTI Oil Pump Replacement
346 views 1 reply 2 participants last post by  Astra220
#1 · (Edited)
Astravan 1.7DTI
Year: 2000
Hello
I need to fit a new oil pump:
I know I need to remove the timing belt etc.
1 Do I only need to remove the sump pan at the bottom of the engine?
2 Does the sump pan have a gasket or is it a sealant?
3 Is the BGA brand Oil Pump any good - they say they fixed the nut coming loose problem?
4 I’m fitting a new timing belt kit. Is INA a good reliable brand?
Any other useful tips would be much appreciated
