Hi,
Does anyone have a copy of the full pinout for the delco ECU as used on the Z22SE Astra G 2.2 please?
I can help you out so far @Ayresyy
i can pm you pdf's of the ECM wiring diags and pdf's of the X77and X78 plugs,the actual pinout list doesn't come up so you'll need to work which pin does what from the pdf's,let me know if you want them
That would be a big help, thanks. I am trying to get cruise working on a VX220, so I need to find out where the 3 cruise and clutch switch wires need to feed back at the ECU.
