Hi guys please advise iv checked with a obd2 scanner the buttons on the stalk are engaging and disengaging the cruise control however nothing happens the car doesn't hold any speed be it 50, 100, 140 kmph the light on the cluster does not even come on however the ecu sees that you have clicked the buttons on the stalk. Please advise if there's something I can try it's frustrating not being able to use cruise control.
Check the brake and clutch switches are both working correctly.
Thanks a lot am i correct in thinking this is above the pedal? Will definitely check this tomorrow hopefully its something this simple
