1 - 12 of 12 Posts
Hello
I recently purchased an astra h gtc 1.8 140ps .
What is the normal temperature for this engine.?I noticed that the radiator fan goes on when the engine hits 107c.Is this right?I think its too high..
I have a 2006 ASTRA SRi 1.8 (125PS) and temp doesn't go above 92c. Sometimes, on heavy traffic it can reach a max of 94c.
Which engine XE or XER ?
the cooling systems are quite different between the two engines
I think i must replace the thermostat..When driving i have about 88-90c temperature and sometimes drops to 78c.If the thermostat opens at 105c whats the normal driving temperature?
Are you having any problems with the thermostat at all? Any errors?
No i dont have any errors.But i dont know the normal temperature this car should have.If the thermostat opens at 105c driving with 88-90c isnt too low?
Depends on the ambient temp you have where you are as to whether this is OK. You can check the stat isn't stuck open by feeling the rad, it should be cold until the temp is reached when stat is supposed to start opening.
1 - 12 of 12 Posts
