1 - 7 of 7 Posts
hi guys wonder if you can tell me does the z16xe have 2 oxygen sensors or only 1? i can only see one on mine, on the manifold before the cat. but my ecu keeps throwing up code 0136 which is oxygen sensor bank1 sensor 2. but i have looked up and down the length of the exhaust but can only find the 1, i have replaced the one before the cat but it is still throwing up this code. any help would be very much appreciated, thanks
Michael
There is a second oxygen sensor on all of the petrol 'Z' engines, AFAIK. You should find it on the non-engine side of the cat.
i have recently changed the manifold and cat, and have checked all over, there is definitly only the one at the top of the cat.
In which case you will probably find a plug somewhere that should have an oxygen sensor plugged into it.
What year is the car?
get underneath and look up the back of the block on the drivers side theres a bracket with a plug on it that the second sensor plugs into
i've just changed my manifold and thats were mine was Z16xe
1 - 7 of 7 Posts
