Hey guys, basically when i bought the car the screw holding the door on was slightly loose so when the door was opened/closed, it was catching on the side skirt...
I tightened this and thought it was all good, but it had started to catch still and kept getting worse. Eventually the trim got lose and the glue wasn't holding it, the paint work is also getting messed up because of it!
Any ideas? I was told it's supposed to be bolted on, but when i look inside it's just all glued :s Any advise would be good, any products you would recommend?
I've come across this a few times if the side skirts are not factory fit. The side skirt has been placed slightly in the wrong place. I would advise removal and refit with fresh glue
It was factory fitted though! Think that would be the best option though.
