1 - 7 of 7 Posts
I changed the battery on my Twin Top and immediately afterwards the window stopped operating correctly when I opening and closed the door. It only went down when opening the door not up when closing it. Same on the passenger side and the TT master window switch does not work. When I operate the roof everything works fine apart from the windows.
Any suggestions will be appreciated.
I have tried disconnecting the battery again but it made no difference.
king of the w4nkers
This happened to me on my t8 a couple of days ago when i replaced the battery. This isnt really help, but i just left it, and after a few starts, it sorted itself out and no everything works fine now
A.O.N. - Full Member
hold window down button until window opens and continue to hold for 10 seconds, then hold window up button until it closes and continue to hold for ten seconds, repeat for other window, reset complete :D
I'm impressed the 10 second procedure worked and everything does what's its supposed to
Thanks for your responses it's much appreciated
1 - 7 of 7 Posts
