1 - 11 of 11 Posts
I've noticed some wind noise somewhere on the offside passenger door, I haven't got any wind deflectors fitted. I was wondering is there always slight wind noise on the 5 doors Astra H.
I've checked that the window was up correctly and the door was fully shut but it was still there. Would this be a case of a new door or window sill needed.
Cheers in advance.
Ive had 2 Astra H's and both had wind noise problem. Both had the same problem, it was in the top right corner of the window (looking from the inside, drivers side), if you pushed the seal up the wind noise would stop... but then would start again once you let go -.-
Yep exactly the same as mine!! Rubbers seem fine to me too!
1 - 11 of 11 Posts
