My astra started making a whirring noise about 2 months ago it gets worse between 20-50 mph then quietens down. Gets quieter when I turn left but slightly louder when I turn right. Thought it could have been my brakes so checked pads and discs but only found drivers side was slightly more worn than other side. Changed driver bearing hub this weekend with no difference. Any ideas please.
Make sure it's actually the front as may be the rear, also for some odd reason the little grit guard behind the front disks has been known to rub on the disk as it starts to loose rigity as rust takes hold
