It is always good to change the oil, especially in the problem-prone M32 transmission. In that gearbox should pour more oil than the official specification says, but don't remember how much.
Please people if the m32 is gonna fall then a non Serviceable oil change is gonna have no effect on the outcome. It will fail anyway. Placebo. Spend the £30 on some wind deflectors 😁
Oil degrades, leading to less protection & therefore wear. Pretty cheap service item to help prolong the life of the box...
Then again, if you wish to spend money on some wind deflectors then that's your choice.
Fuch Titanfluid as Ant21 said and also to put about 3 litres in which is what most M32 gearbox builders will tell you. Make sure you can undo filler plug first before draining oil.Hopefully as its a 2012 model it might have the modified end case with a bigger 6th gear bearing and the oil channel that supplies oil to it.
Best way to look after the gearbox is not to abuse it, you can change the oil every month but just that alone will not guarantee longitivity. It just a placebo effect. Your box will give out and you'll be saying "i don't know why this has happened as I changed the oil regularly". Spend ya time and money on something else 🙄
