We have a watt's links on the rear axle in Astra J. Does anyone thought about adding it into AH?
How can you? Its a tottaly differant set up...
Not exactly. Rear axle has a lot of similarities with AH. The support linkage is mounted to the body. The matter is in mounting points (for links) in rear axle.
Sounds like you have done more research on this than the rest of us - best get the grinder and welder out, then get to it. Don't forget to post pictures! ;)
