1 - 14 of 14 Posts
Hi I have a Astra h vxr and I have only just bought it my first one love it ? but the climate control module is not working. So did usual checks fuses and stuff and realise k7 relay not in fuse housing would this stop it working. But in my climate control panel I have heated front and rear screen Also not working. Need help !!! Any advise on what may be causing this. Is it the fact there is no relay? Or something else ?! Thanks ?
Super Moderator
This is my UEC (also VXR with ECC), I have a black relay in K7 which I believe is the heater fan slot.
So I'd assume that might be your problem.
33286
Super Moderator
As above, the front screen isn't heated, all the button does is automatically direct the vents to the screen and turn the fans to max for demisting purposes. Are you sure the rear heated screen isn't working? Does the light come on? Other than it getting warm there is no other indication.
1 - 14 of 14 Posts
