1 - 8 of 8 Posts
Hi,
I`m looking to buy a used 5 dr SRI 150 in the next month or so. Idealy i want black, silver or red with the X-pack. Looking for an 06 or newer with less than 40000 miles for approx £8000.
Is there any specific things I need to look for when checking over the motor, common faults etc?
What is your used car checklist?
Any comments appreciated.
Cheers
Phil
A.O.N. - Platinum Member
The main stumbling blocks with the 1.9 (150) is the egr valve and the switl flaps.
When you go to see the car do the pedal test to see if there are any errors stored on the ECU, this should give you a good indication if the above 2 components are OK or not,
To do the pedal test..
Fully press the brake and accelerator pedal.
Turn the key in the ignition 2 clicks, (do not start the engine)
Error codes should be displayed on the tachometer
After that the things you should look out for are just the usual, service history etc
Thanks Herc,
Good to know about the pedal test, if there are no faults on the ECU does it flash OK or just not do anything?
A.O.N Regional Organiser - Wales (Craig)
that's good to know, will go and test mine now :D is that just on the astra's or can it be done on any model?
AON - Full Member
If there is no fault codes i may also come up with just ECN 00000, thats what my astra does when theres no fault code, though i have heard others saying it doesnt do anything when theres none (y)
Cheers.
Been browsing the site over the last day or so researching swirl flaps. How common a problem are they? Is it a recurring problem or have vauxhall fixed the issue?
I'm a little concerned as the last thing I will need after buying the car is to pay out another £700ish on engine repairs.
Put my mind at rest please.
It isnt a recurring thing if you but the Regal IPF and block the EGR off! Otherwise it will die again eventually! I current have nfg swirlflaps on mine and its going to cost me £700
1 - 8 of 8 Posts
