1 - 16 of 16 Posts
My twintop didn't come with a sport button but instead it has a button to enable and disable the reverse parking sensors. Since I would never want to disable those sensors I was hoping I could use it as a button to enable sport mode. Has anyone tried this before? Would it even be possible?
It’s not possible, you need the sport switch, depends on model as well whether it’ll work
Astra j estate sri
this has sport button and parking sensors
also needs new centre console
Vauxhall Astra H 04-11 Centre Console 13100109 | eBay
at moment has only 2 slot for lock and parking sensor switch
all depends on IPC support sport button...some IPC dont support it
want to retrofit sport button...maybe also adding missing wire loom for sport button
i retrofit sport button my astra h estate there is missing wiring loom from hazward switch to IPC
then reprogram it via opcom
I don't get why it specifically needs the sport switch. It's not like there's anything programmed on it right?
Any idea where I could find a list with supported models?
I already have 4 button slots of which two are chair heating, which I definitely don't want to lose so I'd have to replace it with the sensor button anyways.
What exactly is this ipc thing?
Any idea if some cheap Chinese opcom clone would work as well?
Yes it should do..inuse a clone and have successfully reprogrammed a vxr ecu to my sri and reset other components so I can sell them
Astra j estate sri
this has heated seat with sport button but no parking sensor
this is IPC
34671
me too im using clone opcom
You’ll need to find out the correct ident for the ipc, before buying 1, as you may be wasting your money
There is a list, but I can’t find it on google
What model/engine do you have? Other than it’s a twintop?
Discussion Starter #14
Sorry for my late reply.
Its a 1.9 cdti opc line twintop
Chances are it’s just a case of fitting the switch panel, the 1.9 should be set up for it
Discussion Starter #16
Sounds good, but what I still don't understand is why I wouldnt just be able to rewire the parking button to wherever the sports button is supposed to be connected to. It shouldn't be able to tell the difference between them right?
1 - 16 of 16 Posts
