1 - 7 of 7 Posts
Getting quite **** about preserving my paint and underside, so before it gets too cold and i loose intrest, underseal!
What stuff to use? how much will be needed?
Also if theres any patches of rust, what products to use to restore? Seen plenty in halfrauds but they tend to lean towards one brand and am not asking a spotty 16yr old that thinks neon will do for sealant....
Cheers guys,
Matty
Hammerite car under body seal, used this stuff in the past as its great, all I will say is use either an old brush or a cheap one, there's no washing it off, even with paint thinners, and wear gloves, and keep it away from the body work. Also stay clear of the spray underseals, never uses them but doubt they could be any good.
Spray underseals are a nightmare you get more on you than the car and no matter how many times you go over one area its still only a micro millimetre thick you cant beat slapping it on with a brush
If there are any patches of rust give them a good sand and then paint on something called vactan.
Not sure on underseal tbh
Discussion Starter · #7 ·
Cheers guys
1 - 7 of 7 Posts
