Hi all,
I've recently discovered a small leak on my 2009 Twintop, I can't seem to pinpoint the origin of the leak. I think I've had it for around 2/3 weeks now and I really want to sort it as best I can before it becomes something worse. The leak seems to be around the drive-side rear window. I've noticed when I get in the car after it rains a small pool of water on the plastic trim behind the driver, maybe 2x the size of a 50p piece.I thought I had fixed this leak when I found a small part of the rubber gutter overlapping the plastic roof trim in the wrong area but not sure. Having gone around the car I've only seen a leak here with all other areas dry. The car is parked in a nearly level area. I tried throwing a bucket of water over the car this evening to see if I'd spot anything but no luck.
Any thoughts or ideas on where this might be coming from/ cheap(er) fixes?
