1 - 8 of 8 Posts
Hi all ,
I have astra h 1.9 cdti dpf dtl but i have problem turbo actuator because never kick
I have no eml light on , and i have pedal test but no error codes
I change boost controller solenoid but i have same problem
I have checked voltage with oscilloscope in boost controller sensor and always i have this square wave
Duty cycle at idle is 73%
And in high rpm 70-71%
ps . i have remove dpf , and i have remove in ecu dpf
Need to check the boost pipes, map sensor and egr bud. Reason I asked about the twin top/auto is because they are the only 1s fitted with a dpf
Thanks for your reply , i have astra h caravan dtl
I have check boost pipes , map sensor and egr valve , i change solenoid boost controller
But same problem
I thought of something else for twintop/auto , sorry
1 - 8 of 8 Posts
