Hey lads I have a bit of a problem, the two lights came on. If it helps I had to brake hard before they lit up. So I stopped the car and checked and they went off but like 5 mins after I heard a clink and they came back on also the speedometer started beeping and moving when the ignition was turned on......i do need new brake pads so, what do you think guys?
33978
Hey lads I have a bit of a problem, the two lights came on. If it helps I had to brake hard before they lit up. So I stopped the car and checked and they went off but like 5 mins after I heard a clink and they came back on also the speedometer started beeping and moving when the ignition was turned on......i do need new brake pads so, what do you think guys? View attachment 33978
It will be a wheel speed sensor. Which is built into the wheel bearing.
Means traction control and ABS will not work until its cleared
Sent from my ANE-LX1 using Tapatalk
