1 - 13 of 13 Posts
So this weekend's job is to hand paint the calipers in situ.
I've already got the degreaser and masking tape in so I picked up Halfords blue caliper paint, Wynn's brake and clutch cleaner and a set of wire brushes.
Planning on degreasing and cleaning the wheel arches, struts, springs etc and detailing the alloys after each caliper has cured. I hope to get all 4 done but if I get the front done at least this weekend, I'll be happy.
Aluminum can Tin Tin can Beverage can Publication
Hood Automotive lighting Blue Motor vehicle Bumper
Wheel Hood Tire Automotive lighting Automotive tire
Looks good pal, reminds me I need to re-do mine.
Cheers 👍 Really happy with the colour. It's darker than the original but not a million shades away and, 2 calipers down x 2 coats each and you wouldn't think I'd used any out of the tin - it goes for miles.
I've been looking at the front sub frame while I'm under there and I think it would benefit from a bit of tlc or scrub clean and paint. The car's due it's MOT in June so I may ask if I can take a look while it's up in the air 🤔
Yeah it's the exact same paint I used when I re-done mine first time round. Good stuff and as close as you'll get to factory.
For the subframe I've been thinking the same. To do it properly it ideally needs removing, blasting and powder coating...
I've just cleaned mine up and then injected every cavity I can find with Bilt Hamber S-50 cavity wax.
Not even half a can pal. A little goes a long way!
It's just reminded me to go find my old build thread! Surprised most of the photos are still working 😃 - There's a bit in there where I've undersealed the whole chassis too...
Discussion Starter · #9 ·
👍 I will have a read of this tonight (still in my "don't you dare sit on the couch in that" gear 😁). Thanks for sharing. I'll have a look at the Bilt Hammer stuff too. I used their stuff to degrease my engine bay and was happy with the outcome. Cheers for the pointers.
1 - 13 of 13 Posts
