1 - 18 of 18 Posts
Astra j estate sri
are the airbag wires the same?
are they all the same? as in the newer
are they all the same? as in the newer models wheel
all the models steering wheel are the same on mk5 astra
34681
use same original airbag, yellow wires are steering wheel control and horn is plug in to CIM
airbag wire are separated from yellow wire (yellow and purple) wire i tinnk
the airbag is just clip in.. the steering wheel are the same the metal contact plate are horn
only different is leather, steering wheel control are the same...
vxr steering wheel
34682
vxr steering wheel
top man thanks
can I use a newer steering wheel?
Astra j estate sri
top man thanks
yes steering wheel should straight fit, must be from mk5 astra h factory steering wheel leather and VXR
when taking airbag off first disconnect negative of the battery avoiding airbag goes off in face
behind the steering wheel has 2 small hole (spring clip) for airbag release from steering wheel
Personally I’d stick with a mk5/H steering wheel, not a fan of the J steering wheel myself, and haven’t seen any1 retro fit it as yet!
There’s a few on eBay with the flat bottom, tho last time I looked they were about £300
1 - 18 of 18 Posts
