OK so we all know that the astra h vxr rear axle it better than your average astra h but is this the same with the front subframe?
So is adding a vxr front subframe as good an upgrade as the vxr rear axle?
Discussion Starter #2 (Edited)
Caster angles are slightly different which while I'm asking?
I've got the rear axle so if the front is set differently then I want that too 馃槃
According to the diagrams, the subframes have 3 idents, I鈥檇 be very surprised if they were different tho, bear in mind the front suspension is interchangeable between models, the only difference there being spring length/tensity and shock length and rebound
Its all interchangeable front to rear...
But the vxe has a different caster angle from. What I can see 馃 been offered one to match up so I can see before I buy one
That might just be down to the shorter shocks and springs tho, they鈥檒l change the angles considerably on their own
