munes did it i forgot i had my budgie in the back.😃
Thanks all. it was the crankshaft seal indeed.
Thanks for the reply! I tested my intake manifold, the 'orange nipple' is still there and with the rocker cover off I can pull a vacuum on the head port that does to the intake manifold and I can blow through it. Which in my view means the valve is OK. A garage changed my rocker cover but I think it's faulty as I have even higher crankcase vacuum than I did with the original one. I don't have an Astra, it's a Meriva. But has the same 1.4 engine as your one. I have another rocker cover coming next week I hope that solves the problem as the car has only done 14500 miles! 2013 1.4 turbo.Hey Phil, yes all good on my side. Apart from what you mentioned I also changed the induction manifold on my side. I'm currently on a 5000 miles Euro trip and the car is behaving very well. However, the first day when I drove for 12 hours under high heat I got a code 89 on the dash and the turbine stopped working. This was fixed after restarting the engine and haven't had the issue since. I will check what the error was when back home next week.
Hi PhilGG, was the orange nipple valve easily visible? My car is exhibiting the same symptoms, but I couldn't see the orange/red value. I checked the blowby hose, and the check valve in that appears to be fine.Thanks for the reply! I tested my intake manifold, the 'orange nipple' is still there and with the rocker cover off I can pull a vacuum on the head port that does to the intake manifold and I can blow through it. Which in my view means the valve is OK. A garage changed my rocker cover but I think it's faulty as I have even higher crankcase vacuum than I did with the original one. I don't have an Astra, it's a Meriva. But has the same 1.4 engine as your one. I have another rocker cover coming next week I hope that solves the problem as the car has only done 14500 miles! 2013 1.4 turbo.
Often the local garage will use software that says the intake needs replacing. ********! Just go out now. Start it up and see if you have a huge vacuum when you pull the dipstick.Ah, I can't see anything at all, but tbh it's pretty oily so I just don't know if it's dirty, or missing! I was going to try a non-oem rocker cover, as I haven't been able to find an OEM one yet, but may wait until my local garage has had a look!
