Hi All,
I hope you are doing well.
I'm back with a new Astra J issue. I've been experiencing this squeak on warm engine for quite a while now and nothing I've changed so far seems to be fixing it.
I've replaced the following:
Link with video here
Many thanks in advance.
- V-ribbed Belt - this was the first to replace. no change. I did notice a difference to the one I had installed on car previously. This is 1398 mm and the previous was 1397. But I don't think that mm would do any difference. https://www.eurocarparts.com/p/ngk-spark-plug-408992460
- Spark Plugs + Coil Pack at a suggestion of an Astra J Facebook Group member who fixed his issue by doing so.
- Water Pump - I had high hopes with this as my mechanic was certain this is the issue after listening to the engine while the squeak exhibited.
