As far as I know, there isn't one. It is controlled internally by the instrument cluster.Do you know which wire is the signal for the illumination of the speedo only? Do I need to program via tech2 so ignition doesn't illuminate speedo or is it all off one wire?
By instrument cluster do you refer to the speedo unit itself? Or Is there another circuit board somewhere?As far as I know, there isn't one. It is controlled internally by the instrument cluster.
The signal from the light switch goes to the cluster to tell it the lights have been switched on. The cluster then decides for itself whether it should illuminate or not, depending on the state of the ignition switch, door switches etc.
Yes. The instrument panel controls the gauges and warning lights, as well as acting as inputs and outputs for data from the CAN bus.By instrument cluster do you refer to the speedo unit itself? Or Is there another circuit board somewhere?
So the instrument panel controls the illumination lighting on all parts of the dash, not the dimmer switch? Can you program it with tech2 so the instrument panel won't illuminate from ignition and will only illuminate from lights on?Yes. The instrument panel controls the gauges and warning lights, as well as acting as inputs and outputs for data from the CAN bus.
Yes - the dimmer switch just tells the instrument panel to increase or decrease the brightness of the illumination.So the instrument panel controls the illumination lighting on all parts of the dash, not the dimmer switch? Can you program it with tech2 so the instrument panel won't illuminate from ignition and will only illuminate from lights on?
Do you know of any tech2 guys out suffolk way? I have got a project going on but seem to have hit a brick wall and need some info. Need to see how tech2 can alter the illumination.Yes - the dimmer switch just tells the instrument panel to increase or decrease the brightness of the illumination.
I seem to remember that there could be an option in TECH2 to change how the illumination behaves when the ignition is switched on. Could be wrong though...
