Hi guys,
this is my first post here. I own Astra H, 2005, Z19DTH, 120ps, 16V, Sport! (Y)
Last few days when I start my car I get a yellow lamp (car with mechanic key over) OFF after start, than ON for a few seconds. Then lamp is OFF again and I do not get it ON again that day (few restarts) until next morning and new start. All lights are off after and car is going excellent.
Nothing on small display except mileage.
I tried to read code with brake-acc trick and I get ECN:
070458
038008
First one is: P0704 Clutch Switch Input Circuit Malfunction CRC (Electronic Cruise Control) B-010
but clutch switch is ok, because it's working ok when I try cruise control... CC is off when I press clutch.
Second one:
P0380 Glow Device Circuit High Voltage C-033
P0380 Glow Device Circuit Low Voltage B-020
P0380 Glow Device Circuit Open Circuit C-033
P0380 Glow Device General Error C-033
P0380 Glow Device Powerstage High Temperature C-033
so.. question is.. what is second one fault? What is Glow Device (is that a diesel fuel preheater?) ?
There is no other lights on except this, so I just want to know is this something important or it's just a glitch! :sus:
Thank you in advance...
Branek
P0380 Glow Device General Error this is more than likely the fault code your getting, the glow device is by the battery (silver box with fins on) and the clutch switch code will be stored from a non present fault
Thanks for fast response... :)
So, preheaters... I guess I need to sort this out before winter... now is 35 degrees Celsius here in Serbia... :)
Thanks again... :)
