OK so I fitted an ecu, cim, fuse boxes and abs pump to my astra sri z20ler and it's thrown up a steering angle not calibrated fault C046-39 and C0460-4B
Steering angle not calibrated
And steering angle open circuit (malfunction)
Im guessing there is not a lot I can do as I do t have the pass card for either cars, I've done the turning the squib till it goes tight then back 2 turns till the arrows meet but no change.. All steering controls work asd oes everything else
I can get the code extracted for my car but not from the vxr...
Does anyone have any suggestions?
I didn't think you needed the pass code for re calibrating the angle sensor? Could be wrong. You can do this with Op-Com though.
Yeah I thought that to but I tried 4 different devices to reset it and all asked for the 4 didgt security code.. I tried opcom and it just comes up with start activation and then does fek all
