Retrofitting TPMS
Ok the first thing we need to do is check a couple of things.
Pins in the rear fuse board.
The most important one is the one at the bottom.
You will also need to check you have the following wires on the grey round plug.
The wires you need to check for TPMS are 1 Black & 1 Green/Blue
There should also be other Black and a Green/Yellow (I believe these are for the rear number plate light)
There is a couple of other wires on this plug but I'm not 100% sure what they are for.
If you have the above this retrofit will be so much easier and cheaper.
I've not found any mention of any fuses that are used for the TPMS system.
So the parts you will need are as follows.
Rear loom please pick the loom that meets your car and make sure you add the TPMS into it.
<tbody>
</tbody>
TPMS Sensors for the Wheels you will need 4 of each of the below items.
<tbody>
</tbody>
TPMS ECU
<tbody>
</tbody>
You can fit the loom yourself and also the TPMS ECU, you will have to get a tyre place to fit the TPMS sensors in the wheels phone around and see who has the tools to do it I paid £24 for them to be fitted the nuts need to be done up to 8nm.
You will find the following howto's helpful for changing the loom over and fitting the TPMS ECU.
How to remove rear bumper
Retrofit flex floor
To change the loom over you will need to remove the trim panel from the load area to reveal the the fuse board fully you will also need to remove the rear trim panel, then remove rear bumper (don't need to take it fully off)
disconnect the old loom and remove from the car, then run the new loom though.
Install the TPMS ECU it fits behind the bumper
I used a couple of cable ties for extra peace of mind
You will need to plug the plug into the board.
There is only 1 pin in this plug for TPMS and the wire colour is Purple/Green.
Put the car back together and go and get you TPMS sensors fitted to the wheels
You will then need to get TPMS activated Pecky based in Wolverhampton can do this dealerships seem baffled by any retrofits
Part Number | Description | Price |
13253575 | HARNESS, ASSY., REAR BODY (IDENT 4UJ) (EXCEPT PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (EXCEPT REMOVABLE TRAILER COUPLING) (EXCEPT FLEXFIX SYSTEM) | |
13288746 | HARNESS, ASSY., REAR BODY (IDENT 4UN) (EXCEPT PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13345919 | HARNESS, ASSY., REAR BODY (IDENT 5G6) (EXCEPT PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13288745 | HARNESS, ASSY., REAR BODY (IDENT 4UM) (EXCEPT PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (FOR FLEXFIX SYSTEM) | |
13345917 | HARNESS, ASSY., REAR BODY (IDENT 5G4) (EXCEPT PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (FOR FLEXFIX SYSTEM) | |
13288743 | HARNESS, ASSY., REAR BODY (IDENT 4UK) (EXCEPT PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (EXCEPT REMOVABLE TRAILER COUPLING) (EXCEPT FLEXFIX SYSTEM) | |
13288749 | HARNESS, ASSY., REAR BODY (IDENT 4UR) (EXCEPT PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13345920 | HARNESS, ASSY., REAR BODY (IDENT 5G7) (EXCEPT PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13288748 | HARNESS, ASSY., REAR BODY (IDENT 4UQ) (EXCEPT PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (FOR FLEXFIX SYSTEM) | |
13345918 | HARNESS, ASSY., REAR BODY (IDENT 5G5) (EXCEPT PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (FOR FLEXFIX SYSTEM) | |
13288744 | HARNESS, ASSY., REAR BODY (IDENT 4UL) (FOR PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (EXCEPT REMOVABLE TRAILER COUPLING) | |
13288753 | HARNESS, ASSY., REAR BODY (IDENT 4UW) (FOR PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13345921 | HARNESS, ASSY., REAR BODY (IDENT 5G8) (FOR PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13363096 | HARNESS, ASSY., REAR BODY (IDENT U24) (FOR PARKING PILOT SYSTEM) (EXCEPT TYRE PRESSURE MONITORING SYSTEM) (FOR FLEXFIX SYSTEM) | |
13288747 | HARNESS, ASSY., REAR BODY (IDENT 4UP) (FOR PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (EXCEPT REMOVABLE TRAILER COUPLING) | |
13288751 | HARNESS, ASSY., REAR BODY (IDENT 4UT) (FOR PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13345922 | HARNESS, ASSY., REAR BODY (IDENT 5G9) (FOR PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (FOR REMOVABLE TRAILER COUPLING) | |
13363097 | HARNESS, ASSY., REAR BODY (IDENT U25) (FOR PARKING PILOT SYSTEM) (FOR TYRE PRESSURE MONITORING SYSTEM) (FOR FLEXFIX SYSTEM) |
<tbody>
</tbody>
13348393 | SENSOR, WITH VALVE (FOR TYRE PRESSURE MONITORING SYSTEM) | |
24455308 | NUT, TYRE VALVE STEM (FOR TYRE PRESSURE MONITORING SYSTEM) |
<tbody>
</tbody>
TPMS ECU
13321961 | Control unit, tyre pressure monitoring system |
<tbody>
</tbody>
Retrofit flex floor
