My coolant reservoir had some small fractures which was causing the car to start overheating a little bit.
I replaced it with a new one, not OEM.
The coolant level sensor was working correctly before replacing the reservoir, but after replacing it is always notifying on the MFD that the level is below minimum.
I'm thinking maybe the aftermarket reservoir can't work correctly with the OEM sensor, or the sensor has just gone offline after 17 years of service.
If anyone has the resistance that should be output when testing with a multimeter will be greatly appreciated
