Hi All,
My ECU on the car gave up hence the swap with same part number
However I am stuck and cant get into the Immobilizer to re-program as security code isnt accepted.
I have Security code (7994) of Old ECU and PIN (0080) for replacement ECU. I will write exact steps that i have taken to get this going, if anyone can throw some light, what did i do wrong or what went wrong, please!
Connected Opcom -> Engine -> Programming -> Reset ECU -> Entered code 7994, message received " ECU reset successful.
The immobilizer Spanner light started to flash on dash.
Replaced the old ECU with New (used one)
Connected Opcom -> Checked the fault codes -> showing the Immobilizer not programed ( as it should be) -> reset the replacement ECU using its pin 0080-> ECU reset successful.
Next I went to Body-> Immobilizer->Immobilizer programming -> asks for security code -> I entered 7994 but it didnt accept, message saying wrong code entered. I also tried 0080 but same response.
However I could access IPC using the old code 7994 but cant get inside Immobilizer or CIM module.
Any help is appreciated, thanks!
