1 - 8 of 8 Posts
Today I cleaned my brakes and the rear ones are drum brakes. (with a lot of dust inside ;))
My car is a 2004 petrol Astra H.
I was thinking, is it possible to replace the rear axle with a VXR one so I've 4 disc brakes instead of those drum ones?
Or is the VXR rear axle too small/ big?
Rear axle is the same, is it 4 or 5 stud wheels you have tho?
That was the reason I asked about 4 or 5 stud, for the Aggro swapping over the fronts to 5 stud, be as easy just to swap the rear for a similar axle as what Ul you have just now
Discussion Starter · #7 ·
Too bad...
I'd have to change my alloys in that case, as they're 4 stud.
I think I'll wait and change some other things first before I take on this project.
By the way, would you recommend to buy used ones or new ones?
1 - 8 of 8 Posts
