1 - 8 of 8 Posts
Hi,
I got this weird issue with the left light on the bootlid that stays on whatever my lightswitch is set to, it stays on.
The car is a 2012 GTC. I switched my DRL and headlights to LED, don't know if that is relevant.
I don't get any errors on the dash either.
Do you guys have any clues?
Here's a picture:
https://photos.app.goo.gl/uGsP5kkiTYRH6pS49
i would also venture fog light, my rear fog light is on the driver side... and im pretty sure that Light thats on is the fog light.
Do you not get the little fog light symbol on the dash?
Thats no the foglight, the fog light is the one below.
If youve changed to leds then i would point at that being the problem.
Hi,
Thanks for the replies. No, it's not the fog light. the fog light is lower on the same level as the reverse light on the right light unit.
I've tried disconnecting the battery for some sort of reset but that didn't help.
Could it be some sort of control module?
A very late reply by my but someone else might benefit from it.
I reverted back to all stock non led lighting. That didn't work. Eventually I noticed when I slammed the boot the light lit up. So I replaced the bulb and haven't seen the issue since.
Thanks for coming back to post the solution. As you say, it might help someone in future, so thank you. And glas it's sorted!
1 - 8 of 8 Posts
