having a mare guys!!
were going newquay camping at the weekend, am i being thick but does the rear bench move on the H, what im saying is, does it llift from its position and tuck into the footwells, so the rear seat can be pushed down flat?i cannot seem to get it to budge!
also what pressures should i run fully laden and unladen, with 19"vxr rims, and derv up front?
cheers!!
AON - Full Member
I think it can only come out (with great difficulty i might at) I tried to do it before, and even took it to vauhxall, and they said they aren't designed to be lifted. You can remove it like said above but it can be hard to do, ive tired may of times and give up each time, its a the design of the latch is werid or something, you have to push and lift or something at the same time.
the rear bench can be removed fully but it doesn't tilt forward. the rear folds almost flat over it anyway - i put my bike in the back all the time that way and it works fine
