how do u reset the total closure in the car when disconnecting the battery?
Quick!!
Ian
A.O.N. - Platinum Member
The Total closure? not sure,
If you are talking about the windows going all the way up and down after you press the button for just a second, then all you do is the following
Press and hold the down button until the window is fully open, then keep it pressed for a further 5 seconds,
Then press and hold the up button until the window is fully up and hold for a further 5 seconds,
This should sort your issues out buddy (Y)
na i think ie fitted the unit incorectly this is rediculus
ok the original total close is working now thanks herc ur da man
now to get my unit working
now a need to work out which cabls go where
