1 - 11 of 11 Posts
Before I start pulling my hair out and throwing this HU out of my window on the motor - can someone please help me with the wiring.
I bought the unit off ebay last week and when it arrived the wiring loom was like below (see picture). I emailed the seller and he said that halfrauds done a bit of DIY on it (i can see that!!!) but he says it still works.
I went out to a car audio place and have bought the following to work with this "DIY'd" cable:
CTSVX002 Vauxhall canbus stalk adapter
Pioneer Lead for connect2
Autoleads PC5 Amplified fakra aerial.
Can someone please tell me what is supposed to be connected to what in this picture as I have plugged it in as it is and it doesnt seem to want to power the stereo or do anything for that matter!
P.s. - if you cannot see the cables properly then let me know and i will type them out.
Thanks guys!
Halfrauds have had something else piggybacking that loom. Plug all the matching wires together and the unit should power up
You said to rewire them all so they colour match. halfords have put yellow to red....now im even more confused! lol
yellow to red is common, sorry should have explained that bit, as in some cars yellow is permanent live and red is ignition live, in other cars this is reversed. It is simply a case of switching the yellow and reds around until the on/off and memory functions work correctly
Discussion Starter · #8 ·
SORTED! just wired red to red and yellow to yellow and it powered on. Cheers fella!
Easy..
Yellow/grey to yellow/grey
Black/grey to black/grey (earth) by the way leave the light green wire in the earth as it is if you wish to use the screen without the hand brake on)
Red/grey to red/grey (this is the one that is cut and not connected)
Plug the blue/grey into the blue on the falkra adapter, this will put power to it for better radio reception.
Discussion Starter · #11 ·
Easy..
Cheers mate - was unsure about the blue cable on the adapter!
1 - 11 of 11 Posts
