Part Numbers For The Astra G
67K views 120 replies 60 participants last post by  Kimmo
#1 · (Edited)
Add your Part Numbers
GSi (OPC) Front Bumper
Part No: 9270160 - £265.00 + VAT
GSi (OPC) Rear Bumper
Part No: 9270166 - £407.00 + VAT
GSi Mesh/Grill
Part No: 9270161 (Centre) - £11.55
Part No: 9270163 (Offside) - £5.75
Part No: 9270162 (Nearside) - £5.75
GSi Fog Lights - Part No: 9270157 - £89.00 each!
GSi B Pillar Foil (3 Door Models)
Part No: 13126009 - Drivers side door - £11.15 + VAT
Part No: 13126010 - Passenger side door - £10.55 + VAT
Part No: 13126021 - Drivers side door rear quarter - £10.55 + VAT
Part No: 13126022 - Passenger side rear quarter - £10.55+ VAT
Tinted rear lamps
Part no: 93175669 - Drivers side - £49.40 + VAT
Part no: 93175668 - passenger side - 48.35 + VAT
SRi Turbo (Prodrive Kit) ...
SRi Turbo Front Bumper - (Does Not Include Foglights)
Part No: 93174616 - £345 + VAT
SRi Turbo Rear Apron
(Single Pipe Exit) - Part No: 93174617 - £148.00 + VAT
(Twin Pipe Exit) - Part No: 93175478 - £147.00 + VAT
SRi Turbo Side Skirts
(Left) - Part No: 93174203 - £193.00 + VAT
(Right) - Part No: 93174681 - £193.00 + VAT
Traction Control Switch
Part No: 90437527 £12.50 + VAT
Traction Control Loom
Part No: 9270597 £10.75 + VAT
Trim Panel
Black (Single Hole) - Part No: 90437593 - (Three Hole) - Part No: 90437561
Gun Metal Gray (Single Hole) - Part No:13129777 - (Three Hole) - Part No: 13129779
Rubber gromit for air box you'll need three in total
Part no :90448359 - 0.74 + VAT
Rear centre boot badges
Hatch.
Holden - Part No: 9117600 £17.95 + VAT
Vauxhall - Part No: 9117602 £12.55 + VAT
Opel - Part No: 9117599
Coupe.
Opel: 9200445 £8.20 + VAT
Dark style headlights as fitted to 03 Astra's.
N/S - Part No: 93175725 - £95.00 + VAT
O/S - Part No: 93175726 - £95.00 + VAT
Astra G / Zafira A (All Models) Multitimer 9136113 £58.00 + VAT
front revised BCS (Boost Control solenoid) - 55557806 £21.40 + VAT
rear revised BCS - has slightly different connectors - 55557829 £21.40 + VAT
for the older LET version - this was then superceeded by - 55352099 £16.15 + VAT
(front) for LEL,LER and LEH - the later version is compatible with the LET without any need for mapping - 55557806 £21.40
55557829 (rear) - £21.40 + VAT
Vectra C pipe mod
Part numbers
Main Pipe 9177099 - £7.05 + VAT
Adaptor to airbox 9177104 - £6.00 + VAT
Washer Jets "Insignia"
RH jet - 12782509 - 1.89 with vat
LH jet - 12782508 - 1.89 with vat
Sunglasses holder part no : 24413714 £4.76 + VAT
Flatblade wiper part number 93189622 £21.80 + VAT also fits Corsa C and Tigra B
Egr valve Part number 17200272 - £71.50 + Gasket 24411213 £0.72 + VAT
Astra G 1998-2004; Engine codes: Z14XE, Z16XE, Z16SE, Z16YNG, X16SZR, X18XE1
Shall also fit models below:
Corsa C 2001 on; Engine codes: Z14XE, Z16SE, Z18XE
Meriva 2003 on; Engine codes: Z16SE, Z16XE, Z18XE
Tigra B 2004 on; Engine code: Z18XE
Vectra B1996-2001; Engine codes: Y16XE, Z16XE, X18XE1
Vectra C 2002 on; Engine codes: Z16XE, Z18XE, Z18XEL
Zafira 1998-2005; Engine codes: Z16XE, Z16SE, X18XE1
Anti roll bar link for G : 90498745 - £18.60 + VAT
Pads
4 Stud Pads 9195144 - £25.95 + VAT
5 Stud Pads 9195145 - £28.25 + VAT
Turbo Pads 93181189 - £54.00 + VAT
Lambda Sensor (O2 sensor):
There are two - one is located in the pre-cat pipe and the other just before the main cat.
(Front) 9193148 - £102.00 + VAT
(Rear) 9201421 - £103.00 + VAT
AFM (Air Flow Meter):
93181894 - £191 + VAT
9201425 - LET AFM - £129.00 + VAT
Irmscher
Irmscher, chrome effect door pins i9517657
Irmscher smoked side repeaters for G : i1212041
Vauxhall i Line logo - i 9517329 (stick on)
Vauxhall i Line logo - i9517408 (with carrier for radiator grille)
Irmscher Logo - i9517310 (door moulding badges)
Irmscher Badge - i9517339 (for rear end)
Irmscher Logo with silhouette - i9517338 (stick on)
Irmscher Logo with silhouette - i9517407 (with carrier for radiator grille)
See less See more
#25 ·
normal headlights
hi
i understand that the dark ones are
N/S - Part No: 93175725 - £92.00 + VAT
O/S - Part No: 93175726 - £92.00 + VAT
What does o/S and N/S stand for?
What are the part nos for the normal glass ones?
