Hi.
I have the CEL on all the time now. Car still runs perfectly ok.
There is a fix on youtube showing the fitting of a resistor. This is for the low voltage P1113 though.
Will the fitting of the resistor switch the CEL out on my high voltage fault?
Where is the plug that i need to access? The video is not that great in pointing out where i find it.
Many thanks.
(1) P1113 Vauxhall Astra Zafira port deactivation repair Z16XEP DIY fix - YouTube
I'd get some voltage measurements done first,it sounds as though you may have a short to 12v on one of the wires,
probably the 5v feed (black/white) or the signal wire (red/blue),the earth is brown
Hi Valer.
I know nothing about auto electrics so i will get an auto electrician.
Thanks for pointing me in the right direction. I always appreciate your help.
