1 - 1 of 1 Posts
Hello everyone.
i have a problem witH the SVS, i check with obd and i had p037e which is for the glow plugs.
i haven’t checked them individually cos i don’t know how to, but tomorrow i will try disconect the 80A cable on top of battery and wiggle the glowplugs cables maybe will sort it out, otherwise what do you suggest?
can i check the plugs without removing them? ( i have a MM)
what about the other errors b3125/b3130/b3135, apparently is a leftdoor/alldoors circuit malfunction lock/unlock but i can lock/unlock/use windows without any problems.
any idea what should i check or what to do? Is it a fuse for them?
1 - 1 of 1 Posts
