1 - 12 of 12 Posts
I have a 54 plate astra sxi i have just done an oil change and cleaned the maf filter.
Now on start up the car just revs up would be gratefull for any ideas
ian
Which engine ?
Ok that engine doesn't have a maf,just an inlet air temp sensor,
have you checked the sensor and anything else you've disconnected are all back in place ?
when you say "over revving" are you saying it's now got a high tickover,if so what's it revving to ?
Have you been removing anything from around the throttle body ?
did you remove the sensor or spay a lot of cleaner straight in ?
i'm wondering if it's still running on the cleaner
I'm guessing you don't have a scanner that's capable of reading any live data ?
maybe pull the inlet trunking off and see if the throttle body flap is stuck open
1 - 12 of 12 Posts
