Hi i have a problem with my astra G, its leaking AC water from the pipes that go through the bulkhead to the AC drain (as in the picture). Put alot of pressure with an air compressor and its still leaking. Its draining normally outside but also leaking inside when AC is on.
Tire Automotive tire Bumper Rim Asphalt
Discussion Starter · #2 ·
Today i removed the drain of the ac from behind steering rack, it was a real pig to get out took me almost 3 hours of fiddling lol. The rubber aeal was damaged thats why it was leaking. Any idea where i can find a new one online because i cannot find locally? Not even on ebay new atleast.
Automotive tire Flooring Wood Floor Grey
Toy Aircraft Finger Toy airplane Table
Can you not improvise by using bathroom silicone sealant instead to stop it leaking?
