Op-Com readings
4.4K views 6 replies 3 participants last post by  LADmachining
#1 · (Edited by Moderator)
This is from my Astra Z17DTL.
How do I know what is working properly...?
I noticed now the voltages are a bit erractic and when its idling, sounds a bit lumpy. You can see the interior light dimming slightly as all the other displays in the car....
Selected model>,2005,Astra-H,Engine,Z 17 DTL
Control Unit:
Identifier: 0x0704
VIN: W0L0AHL485xxxxxxx
Hardware number:81011943
Motor type: Z17DTL
Part Number:55556829
Software version number: P368_I63DT
Hardware manufacturer number: 0281011943
Software Number: 1037372298P368_I63
Programming Date: FFFFFFFF
Hardware key number: ÿÿÿÿÿÿÿÿÿÿ
System description: BOSCH0100
Type approval number: B04002
Variant programming: 0x00000001
Alpha code: ZH
Hardware manufacturer system name: EDC16
ECU variant coding: 0x000000C5
Measuring blocks information:
Battery Voltage,14.0 V
APP at Idle Position (Accelerator Pedal Position),Active
APP Sensor 1 (Accelerator Pedal Position),0.96 V
APP Sensor 2 (Accelerator Pedal Position),0.47 V
Calculated Pedal Position,0 %
Desired Engine Idle Speed,850 RPM
Engine Speed,852 RPM
Camshaft Speed,425 RPM
Calculated Air Flow,25 kg/h
Mass Air Flow Sensor,25 kg/h
Intake Air Temperature,22 °C
Intake Air Temperature,2.03 V
Coolant Temperature,60 °C
Coolant Temperature,1.62 V
Oil Level,Normal
Oil Pressure,Normal
Engine Oil Level Status,Okay
Barometric Pressure,101 kPa
Barometric Pressure,3.98 V
Boost Pressure Command,104 kPa
Boost Pressure,97 kPa
Boost Pressure,1.82 V
Pulse Ratio Boost Pressure Solenoid Valve,91 %
EGR Position Commanded (Exhaust Gas Recirculation),35 %
EGR Pulse Ratio (Exhaust Gas Recirculation),58 %
Swirl Level Control Solenoid Valve Pulse Ratio,100 %
Throttle Position PWM Servo Signal,68 %
Desired Common Rail Fuel Pressure,24.00 MPa
Common Rail Fuel Pressure,21.78 MPa
Common Rail Fuel Pressure,0.98 V
Fuel Metering Solenoid Valve PWM,33 %
Fuel Metering Solenoid Valve Current,1.28 a
A/C Information Switch (Air Conditioning),Inactive
A/C Pressure (Air Conditioning),735 kPa
A/C Pressure (Air Conditioning),1.1 V
A/C Cutoff Mode (Air Conditioning),System OK
A/C Relay (Air Conditioning),Inactive
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Inactive
Vehicle Speed,0 km/h
#2 ·
Posting that data is is unfortunately not much help, as by it's nature the values do change continuously whilst the engine is running. The key is knowing how much the values should change, and when.
The lights can flicker at idle, if either the alternator is not charging correctly, or the glow plugs are switching on and off (which does happen normally whilst the engine is warming up).
