Hi everyone I have a Vauxhall Astra 1.3 cdti Z13 dth M5, I had a problem with the turbo vacuum sensor, at 3/4 thousand revs the engine light comes on and the turbo
drops power, when I stop and restar the light goes off on the dash and then it repeats, my biggest problem is that oil is spattered on the right side of the engine mainly
near the EGR,manifold inlet,battery,vacuum pump etc its not a lot but I dont have a clue as to where its coming from, except its on the driveway.
I have washed it down used it for a couple of hundred miles and its fine, then the next day it does it again
Im Baffled anyone with pointers your expertise is needed:)
Hi fitzys, I found the problem the oil pipe from the cannister at the rear of the engine which goes to the air intake manifold
was split have ordered one from dealer 18.00 quid I prefer OEM parts have a look at the pics, also a bas%$# of a job to remove
Regards Dave
