Hi Everyone,
i have recently joined the network and after reading several of the prvious threads the network appears a wealth of experienced owners.
So here goes for my 1st ever thread.
I have a set of steel wheels on our 2.2 life and they have a rim size 6.5J X 16 X offset = 37. that i want to change out for a set of alloy wheels
i have seen several offset limitation tables that identify this vehicle with a offset limitation of between 35 - 45.
does this mean I can fit any set of 16 inch wheels in this range ? and for example if my offset is currently 37 and i am looking at wheels with a offset of 39 can i just put these straight on the vehicle?
any help would be greatfully received,Regards Povs
Standard Zafira B wheels
195/65 R 15 6 J x 15 offset 43
205/55 R 16 6.5J x 16 offset 37
225/45 R 17 7.5J x 17 offset 47
not sure if that helps?
Cheers Norhtern Bloke that looks like the same list i have seen ,what im trying to find out is that my current wheels are 37 but the alloys i am looking at are 39's can i put them straight on my car or will i need to do anything to allow the 39's to fit ?
Thanks for your reply though.
39`s will sit a bit further in than your 37`s , but may be wider as well which would bring them out again .. What width are the 39`s ?
Cheers Bainie for your private message reply.The wheels i am looking at are
6.5j x 16 x 39
