1 - 20 of 143 Posts
Right as most of you know I bought a 3 door Sri as my van is fubar, it’s a very clean example, need to either get the drivers door repaired or replaced, other than that it’s 99.9% standard but it’s early days! Lol, it’s a 1.9 8v 120 DT engine, only thing Iv done so far is fit led number plate lights, so it’s basically as it left the factory
Things I need to do
AC compressor seized
Piano black stuff to source
Might put burg front seats in
Bi xenons
Rear lights
Cdc40 and Dab, upgrade speakers
Spacers
Fit sun strip
Vxr body kit
Not sure on exhaust yet
Egr delete
Remap
Tint out the windows
Sort the suspension out
Think that’s it for now
Thanks Micky, didn’t notice where I’d posted it before I added it
This just arrived in the post
Have a few blanking plates in the van that I can use to blank off the manifold, so guess il be busy for about the next hour or 2, as il do the sunstrip as well
If you find a good place to source bi xenons let me know.
So hard to find for a good price. See a load of alfs about though.
Sent from my SM-A510F using Tapatalk
Damit, yea looking for Bi xenons as AFLs require more work to get working.
Besides would have to wait till the car is swapped.
Got part numbers for them?
Want to find a set, and see how to retrofit
Discussion Starter · #8 ·
I got mine from the dealers when I got staff discount, they only give 10-15% now.
Retro fit is a breeze, just need to add 2 earths to each side and drill out the headlight plug with a 1.5 mm drill, or get the headlight adaptor loom just need to swap 2 of the wires round as the adaptor is set up for afls, which means you loose the manual height adjustment
Il dig out the part numbers tho
Huh, do they need balasts?
There is an adapter loom on ebay for afls would this work?
There a guide on fitting these?
Otherwise its led drl headlights for now
Discussion Starter · #10 ·
Need ballasts and igniters, can get those much cheaper than the vx prices, yep the eBay lead is the afl 1, just need to swap 2 wires about and it already has the extra earths
So, you would also need the wires for the balasts and igniters.
Not sure i have the tools for swapping the pins over
Discussion Starter · #12 ·
Fitting is easy, drop the bumper, 3 bolts take the headlight out, unplug the headlight and then same in reverse, honestly it really is as easy as that think I had to program it to having xenon but can’t remember what I programmed, think it was the ipc
Discussion Starter · #13 ·
Very slim screw driver should do it, tho a pin popper is about £6
Yea, swapping headlights is easy. Got a link for the adapter looms?
Also programming does that require tech2?
Discussion Starter · #15 ·
That adaptor sorts out the wiring, it’s more or less plug and play tho
1 - 20 of 143 Posts
