121 - 140 of 162 Posts
Discussion Starter · #122 ·
so it’s been a little while.
I got the eml light on yesterday on the way home from work so I did the pedal test and got 2 codes.
0400 egr valve
p0572 cruise control/brake switch a circuit low
I knew the egr was an issue as I’d had slow starting from cold and recently a slightly lumpy idle on odd days.
so today I’ve fitted a blanking plate to see if that sort the issues there
35029
35030
35031
Does anyone with experience know if I should remove and blank the vac pipe at the back of the egr too?
35032
The 2nd code is a bit of a mystery to me tbh so any advice would be great! Cheers
I'm sure you've already searched but this seems generic to that code
How do I fix code P0572?
The most common repair for the P0572 code is replacing a failed brake light switch.
However, other repairs that may be necessary include:
  1. Replacing a failed cruise control switch.
  2. Adjusting a poorly adjusted brake light switch.
  3. Replacing blown fuses.
  4. Replacing faulty cruise control modules (rare)
Discussion Starter · #124 ·
Hey mate yeah I had a look, seems kinda vague and is possibly an old code.
Ive just been for a little duel carriageway run And the EML light is no longer on.
I have to say, blanking the EGR has made a massive difference to the way it drives!
Much better throttle response and no longer sluggish
I guess it’s a case of getting the code cleared and see if it comes back if possible,
I’ve just bought a decent version of op-com for such issues but haven’t worked out how to or spent the time getting the software sorted on the laptop yet :rolleyes:
Discussion Starter · #129 ·
Got a weird issue with the brake light switch at the minute.
I only had to rear top brake light lighting up and a brake switch fault code.
I bought a replacement switch but it was the 2 prong and mine is a 4 prong (cruise control models).
when I fit the new switch only the drivers side brake light lit up 🤔😅
I’ve ordered a new 4 prong switch but have to wait for it now. Any one else had issues with this?
Discussion Starter · #130 ·
Got the front bumper off before and went at a couple of jobs.
First way checking out and “sorting” the crash bar corrosion. It’s not looking great tbh. I wire brushed it back and tidied up the surface, then hit it with some k-rust.
It’ll have to be replaced at some point as I found a few small rust holes straight through.
35073
35074
35075
35076
35077
35078
35079
Discussion Starter · #135 ·
Got a new (old) motor for my partner today so time to say bye to the Fiesta.
Here’s the new car
35200
35201
35202
1.2 sxi Corsa C
9 months mot
75k miles
£500
Now there are a couple of issues I spotted.
It’s got the dreaded wet drivers side front & rear footwell. Checked the washer bottle and under the scuttle panel, cleared it all out and cleaned up but I think I’ll have to reseal behind the brake master cylinder ASAP.
Also needs a little welding under the battery tray so that’s on the list.
drives well tho so fingers crossed that’s all that needs doing for the time being.
Discussion Starter · #136 ·
all of the wipers and washers stopped working on the Corsa. I checked the fuse and wiring to the loom and seems fine so last night I replaced the motor and linkages for the front wipers.
35264
35265
35266
35267
35268
Got the old one out and the new fitted and still nothing. I’ve ordered a new (2nd hand) wiper stalk to see if thats the issue. I’ll let you know 🙄
Discussion Starter · #137 ·
Weirdly, the front wipers now work but not the rears. I’ve got a rear wiper motor on the way and and new MAF and a wiper stalk.
Weather’s nice today so gave the inside a vacuum and Polish
35331
35332
35333
Discussion Starter · #138 ·
Managed a couple of little jobs between downpours this morning.
1. Fit new (painted) rear bumper
2. Replaced headlights with old clear ones as o/s was full of condensation/rain water.
3. Gave rust on front bumper mount a spray of anti rust primer.
4. Gave it a wash
35381
35382
35383
35384
35385
35386
35387
35388
35389
35390
Discussion Starter · #139 ·
Been hard at it this morning. Coilovers fitted and she’s sitting nice n low
35462
35463
that’s copper grease not rust on the threads.
35464
35465
new droplinks fitted too. I was going to change the track rod ends too but they look fairly new so I didn’t.
35466
35467
35468
Before:
35469
After:
35470
35471
Took her for a short drive and no issues at all. I live on a road with speed bumps and only scrapped very lightly on one (just the angle I went over it).
I will get the tracking sorted and the rear brake pressure regulator adjusted too.
Discussion Starter · #140 ·
Fit the straight pipe this morning. Probably the easiest exhaust fitting I’ve ever done. Off and on no issues 👌🏻😆
doesn’t sound much different but definitely has a bit more poke on acceleration.
just got back from having the wheels aligned as well, much better.
35493
35494
