41 - 60 of 70 Posts
Discussion Starter #41
Been a quiet day home schooling the mancub. Also after almost a week of none stop car work I went to sleep last night with my hands radiating pain, and woke up this morning barely able to make a fist! 馃槄
Resting them today. Ex army and I have problems with early onset arthritis pain 馃槙
But here鈥檚 what yesterday brought.
wrestled the old, seized on droplinks off the focus and fit a new horn (hopefully it passes it mot on Thursday 馃馃徎). Only had to cut and grind one
34321
Also got the welding sorted on the fiesta
before:
34322
34323
After:
34324
34325
still lots of jobs but they鈥檙e the big ones sorted out at least.
Oh and finally got a handbrake gaiter fitted on the Astra
34326
Discussion Starter #42 (Edited)
Thought I鈥檇 do a little garage/workshop segment if anyone鈥檚 interested... not that it matters, it鈥檚 my thread and you鈥檒l read what I give you to read 馃槅
Its a good size, detached 5m x 2.5m single with a pent roof. I鈥檒l just show you some pics from the start of the renovation to now.
First I used an angle grinder with a shroud and an amazing cement grinding disc to grind the floor as smooth as possible. Labour intensive and mega dusty but worth it.
34330
Next I filled in the cracks in the slab and around the edges and repaired the broken entrance slab.
34332
After that came painting the walls. First a fresh coat of white on the top half then the lower grey half.
34333
34334
Next step was the floor. First a sealing primer and then the hardcore paint.
34335
34336
34337
Discussion Starter #43 (Edited)
Then it was time to fit out the gym and workshop
34338
34339
34340
34341
34342
It鈥檚 not this messy anymore! 馃槄
And the exterior needed updating
before:
34343
After:
34344
And some little finishing touches
34345
34346
Discussion Starter #45
Yeah, I mean most of this was done in the first lockdown. The benches were done in the 2nd lockdown. Just wanted to show where The magic happens 馃馃ぃ
Discussion Starter #46
Ok so after finding a lot of bad corrosion on the Focus鈥 rear sills, I鈥檝e been going at the jobs on the Fiesta today to get it MOT ready.
The Focus has nearly 200k miles and really isn鈥檛 worth the money to get it sorted. The Fiesta however has 65k miles and a new clutch. It鈥檚 my partners car and she much prefers it to the tank (Focus) as she calls it 馃槅.
So job one I replaced the 2 rear number plate bulbs. Easy enough.
Job 2 was the handbrake efficiency. The auto adjusters in the drums are terrible on these cars so my first thought was to get the drums off, tidy them up and re-seat the shoes. Then adjust the handbrake from inside the car.
34361
34352
And cleaned up a little
34353
Popped them back on and adjusted the screw beside the handbrake lever (using Haynes manual). It now ends on the 3rd click instead of the 6th! And the cars still as a rock with the parking brake on 馃憤馃徎
34354
Next job was the exhaust blow.
The flange between the cat and flexi pipe is very loose, rattling around in my hand!
Turns out there was no gasket between them at all. Luckily I had one in a draw 馃憣馃徎.
The 2 15mm nuts came off surprisingly easy and I鈥檝e got them soaking in some Pepsi to clean the rust off 馃ぃ
Also cleaned up the surfaces of the flanges. I鈥檒l get more pics when the nuts are ready to re-fit.
34355
34356
34357
34358
34359
Discussion Starter #47
Busy day inside the garage as it鈥檚 been chucking it down all day 馃檮
Got my remaining Fiesta parts together but I had to order a new exhaust gasket as mine didn鈥檛 fit.
Front discs and pads and 2 cv boot kits.
34377
Then I wire wheeled and rust treated the flanges and hangers on the new back box for the Astra.
34378
34379
34380
Wire wheeled
34381
34382
34383
34384
Then treated with some K-rust I had left over and left for a couple of hours.
34385
34386
Tomorrow I鈥檒l give it some anti rust primer and hard wearing paint to protect it.
Discussion Starter #48
After that I gave the workspace a much needed tidy and reorganisation
34387
34388
34389
And annoyingly realised the Astra has at least one slow puncture 馃槫
34390
Discussion Starter #49
Oh also, nearly forgot, I swapped the rusty exhaust nuts into some lemon juice and white vinegar over night and they came out loads better!
34391
34392
Discussion Starter #50
Another day of non stop rain so I鈥檝e been tidying and organising the workshop again. As well as getting some primer and paint on the back box flange.
Taped up ready
34405
34406
I put the primer and paint in some warm water while I made a brew. It鈥檚 freezing in the garage and this should just make the spray more even.
34407
I know it鈥檚 BBQ paint but it鈥檚 high temp, durable and I already had some 馃し馃徏鈥嶁檪锔
34408
Then I did 3 coats of primer and 3 coats of paint.
34409
34410
34411
34412
34413
I鈥檝e ordered a new fitting kit (gasket, bolts, springs) and I鈥檒l get it fitted when I鈥檓 ready to get the rear bumper off and remove the tow bar.
Discussion Starter #51
Nice package arrived today. Big thank you to Barneyrussel for the generosity 馃檹
Vec C 1.9 intake and engine performance flush.
34419
Been cracking on with the Fiesta brakes and cv boots. N/S is done but I鈥檝e had to order a hub puller for the O/S as the spline will not come out the hub with any amount of persuasion 馃サ
N/S:
34420
34421
34422
34424
34423
Exhaust gasket also arrived so when the puller comes tomorrow I 鈥渟hould鈥 get all the jobs done.
Discussion Starter #53
Oh mate, I鈥檝e never seen a lip on a disc as bad as that. Yet they weren鈥檛 even an advisory when it failed its mot 馃え
34427
I'm sure some garages must have partially sighted mot testers, i know of a garage that did a few welding repairs using silicone :rolleyes: on an old transit but the owner was just happy to get the pass so he could carry on working it, it was the inner wings, under the headlights and difficult to get to but that's not the point!
Discussion Starter #55
Small update today.
Got both discs and pads done on the fiesta but that o/s drive shaft is seized into the hub so it鈥檒l be a job for the garage before it鈥檚 MOT. Even with the hub puller, wd40, hammer and punch and a little heat, it ain鈥檛 budging! 馃サ Had to order yet another exhaust gasket too, as they sent me the wrong one 馃槫. It鈥檚 a crush ring fitting.
Anyway, back to the Wagon.
I just fit the Vec C intake with relative ease.
34435
34436
34437
Before:
34438
After:
34439
Also noticed some light sludge in the murky brown coolant reservoir, no oil in it and no mayo under the oil cap. Also no white smoke or overheating so I think it just needs a good flush and change. Probably never been done over 60k miles.
34440
34441
Discussion Starter #56
Small update. Got some goodies today, some cheap wheels and some fluids ready for an engine and coolant flush. And the correct fiesta exhaust gasket finally!
34449
34450
Discussion Starter #57
I apologise for another non Astra update to this thread. I promise I have things to do on it and I will get back to it ASAP. It鈥檚 just been raining heavily for over a week straight, no break! My garden is a lake 馃う馃徏鈥嶁檪锔
So it鈥檚 been another day in the garage with my music and tools
34453
34454
34455
This was a dvd cupboard I got on Facebook for 拢40, painted and put on castors
34456
34457
34458
34459
34460
34461
There鈥檚 still more to do and I want extra shelf space underneath the worktops, but it鈥檚 getting better every time I go in there.
Discussion Starter #60
Cheers yeah it鈥檚 getting there. I鈥檓 gona bring the headlights into the house tomorrow and get to wet sanding them while I鈥檓 home schooling, so watch this space 馃馃徎
41 - 60 of 70 Posts
