1 - 10 of 10 Posts
Courtenay Sport recommend this for the F23, has anyone tried it and found that it made the gearchange really stiff in winter? i've found a couple of VW sourced posts saying it does but that's it so far, its fine when warm so don't think there's a problem with the gearbox.
Isn't 75w or 75w-80 the recommended viscosity? If so, a 75w-90 could make for a baulkier gearchange when the oil is cold, especially in winter.
Cheers,
Guy
Very possibly, i just went by what information they put on their blog, forgive my ignorance but isn't the 75w for cold and 80/90w for when warm? even in winter its fine when a mile or so down the road its up to that that its really stiff.
There is certainly nothing wrong with using the original Vauxhall stuff for the F23 gearboxes, if you just want reliability. I know of several running fairly high power that have lasted for many years with just a swap carried out using the standard oil.
I have 3 of them, 2 of which have been happy at just over 320 BHP so it does the job sufficiently and there are no shifting issues when cold.
@Ayresyy
Thanks for the info, i wanted to try some fully synthetic as even from a year or so old my gearshift has been a bit notchy (so my brother said at the time) now and then, i've had the gearstick rebushed, new gear cables, a quick shift fitted and although better its still not great at times (other times its nice and smooth) maybe that's just F23's in general?
Normally the recommended but this time i tried the full 2 litres, i was thinking of going the full 2 litres again?
1 - 10 of 10 Posts
